Replacement usb c port for ‘20+ 5th Gen?
I’ve been searching high and low to replace my usb A to two fast charging usb c’s. This is not the same sized slot as all of the standard blanks, it’s smaller and almost a square instead of a rectangle blank. This is for the usb A data port next to the cigarette lighter. Yes, I realize that I could just buy a cigarette lighter adapter (but I actually think the fuse is blown on mine) but I’m a unicorn dammit and I want stock appearance. :joy:
Have you checked CH4X4 Industries? They may have what you are looking for.
EXACTLY what I was needing, thanks Hoa!
I use either blue sea or powerwerx. You would have to wire it in but I haven’t found anything that meets the quality or actual output. I don’t think blue sea makes a usb c but between those that’s all I run anymore.
Powerwerx
bluesea
