My 4Runner build
I never do build threads but decided to do one on my 4Runner. The reason I don’t is, I can spend over a year building something. This one is going to be pretty quick. When I was shopping for a new project truck, I took my time looking for something that already had a number of parts on it already. I don’t think anyone on this forum is new to how expensive it is to properly build one of our rigs and the expense is what I was trying to off set, as much as possible.
Here is what I’m looking at
  1. Icon suspension, 3" with reservoir’s, front and rear arms.
  2. Rock sliders, white knuckle
  3. Roof rack
  4. Small front bumper with winch and light.
  5. Rear bumper. Dual swing out with tire on passenger side and fuel cans on driver.
  6. Regear to 4.56 or 4.88
  7. 17" rims with 33"-35" tires
  8. GMRS, Ham radios
  9. Chase light
  10. SPOD or switch pro controller
  11. Tablet/Phone mount, high output USB plugs, “A” and “C”.
  12. Fridge
  13. Dual battery’s and isolator
  14. ARB compressor.
  15. Rear Locker and possibly front locker (Eaton)
  16. Skid plates
  17. Seat covers (Bartact)
That’s my basic build sheet and after a few months of searching I found one that had close to half of what I listed. Two things about buying a used 4WD are, how was it treated and how old is the suspension. The one I got had all the suspension done last year. Three years ago, he went nuts in a "Cali Raised catalog and spent a grip of money.
Here’s what it came with.
Stage 8 Icon. Icon 17" rims, 33" tires. Cali raised sliders, front bumper, Smitty built 10k winch, roof rack with light bar, rear moly panels, inside with shelf and outside driver. Riged tire carrier.
That’s 15K-18K (installed). Not a bad start. I have a 15K budget for accessories, regardless of what vehicle I got. Having these already there means more stuff now.
Here’s a pick of it before I start.
Right now I have a huge pile of parts sitting in the garage and an appointment to get my (4.56) gears installed. What I have installed is my KC Gravity 6 light bar, my dual battery mount and a new Odyssey battery. Its just been too hot. I’ll get install picks and comments as I go. There’s a couple of items I’m trying out so, we’ll see how that goes.
Today I got (most) of the dash work done.
  1. Install tablet/phone platform.
  2. Install high output USB ports
  3. Install GMRS. Run antenna cable inside.
  4. Run power feeds including an IGN feed into the engine compartment for controls
  5. Install light controller on dash and run cable through firewall.
I’ve never liked pulling seats and tearing down dash’s. I did it for a living so I guess I have it easier then most. Proper tools is a must. Wiring things is easy for me. That’s what I actually did. Pulling apart interiors is part of the job.
I brought a 12g feed in from the engine compartment. That will be fused out there and tied to my aux battery. I also needed to tap an ignition feed from inside and run it outside for ign controlled things. Thank you Toyota for not having an ignition power feed that I could use. Ask Matthew what happens when you choose the wrong ign feed for your accessories…Had to throw that dig in.
So.. Ran power feeds, mounted a platform from ICS. Once I had it screwed together is when I realized I didn’t have another ball and extension arm for my tablet mount. While everything was apart, I also mounted a 100w USB-C where the cigarette lighter was(not in picture). That gives me 4 USB-A on the platform and a “C” down by the cubby.
The phone mount is a Ram Mount with an Inductive charger. I love these. Just pop on the phone and go. No cords to deal with. I also have a USB-C cord sort of hanging there. That’s for the tablet.
The next item is the light controller. My requirement here is solid state switching. No relays. That narrows what’s available considerably. I like switch pro and some of my friends like S-Pod. I had heard there are some new competitors out there and decided to try the one by ARB. First off, its half the price. It has solid state switching but does not have current limiting. It uses fuses. The other difference is you do all the setting manually where the big two you do it using your phone. Neither of those are deal breakers for me, especially at half price. Worse case is I go buy one the the name brands and have features I’ll never use.
Picture…OH, I’m printing a new cover for it. I wish they hadn’t put the name on it like that. My girlfriend like’s it though.
Yeah huh.
Don’t have a picture of the radio but it went under the driver seat and the external speaker is in front of it. Something else I forgot was the mic extension. I like plugging the mic into the dash when I need it and not having it there when I dont.
Tomorrow is all under hood stuff. Mount compressor, battery isolator, light controller and if I have time, wire it all.
Day 2
I thought today was going to be smooth. Yeah.Uh Huh
My agenda was mount the ARB compressor, mount the switch control module, mount the battery isolator, install small aux fuse block and wire it all together.
What I did accomplish was assembling the ARB mount, installing it and removing it over the course of four hours. Note here: the compressor bracket never got screwed down. at least I didn’t need to unbolt it each time. OH… I ran out of screws and had to go to the bolt place.
Each time I installed it, I found something under it I needed to do. The biggest issue was the light control module. The bracket I got has a spot for it on the back. Well, it does but it fits another brand that’s way smaller. Somehow forgot to look at that. What I ended up doing is fabing a bracket and mounting it near the battery. Once that was done, I realized I forgot to mount the breaker and power stud. Everything that’s not “Truck” related runs off my auxiliary battery. What I do is bring a feed over to a 3/8 stud and just tap off that for power. The circuit breaker is on the feed line to it then each item I pull off it is fused separately.
Out comes the ARB, again. Mount the power stud and start making my wire loom’s. Wire looms completed, mounted them, reinstalled the ARB and was very pleased with myself.
Yeah, you knew this was coming. Forgot to run the power feed from the auxiliary battery and ignition feed in the loom running across the firewall. Sigh. I really wanted to only have 1 loom across the fire wall.
Now I’m tired. Tomorrow I’ll mount the isolator and hook up that side. I do have a minor issue. I cant find a spot for the mini fuse block. I really don’t want to Velcro it to the lid on my Fuse/Relay center. Its only going to be two fuses for my GMRS and power ports. UGH. Figure it out tomorrow.
Here’s some pic’s of what I accomplished today. The loose wiring shown is not tied in yet. I just pushed it aside so I can move the truck. You also see my mini fuse block I need to figure out where to mount.
Day 3
Slept in and needed to do “Adult” stuff.
What I did accomplish was mounting my battery isolator and circuit breakers. The aux battery box has a plate on the side to mount stuff. What I changed was, adding in crush nuts so I wont need to fumble with holding nuts and bolts in an area I can barely fit my hand. In the picture above, you can see the plate on the right side of the battery. This was my progress for today. I took a picture of the layout but I’m not installing it until I get my wiring routed to it.
Here’s a pic of the mount plate.
Day 4
More “adulting” in the morning. Got started late.
Tied in all my circuit breakers, feed to aux battery, extra grounds. Hooked up compressor, bumper light. I ended up “Velcroing” the small fuse block to my fuse/relay lid. Couldn’t come up with a better place. Ran the power feed to my overhead lights, mounted and ran the wiring to my dust lights.
Still need to finish wiring the relays to my roof lights, wire starlink and fun a feed to the back for my fridge and trailer charging circuit.
Summer Santa brought my fridge today. Still haven’t figured out the mounting.
Two pic’s. One is my dust lights and the other is the auxiliary battery wiring. The other side of doesn’t “look” any different so that didn’t get reshot. The post sitting all by itself on the front is tied to a 50a breaker on the side. This will be my power feed to the rear as well as my overhead lighting feed. The lights will be fused separately also.
On my dust lights. I thought I would share what I learned over the last few years regarding these.
Several years ago, I installed a KC rear light assembly on a friends truck. Its main purpose was a dust light but, the owner wanted the turn signals and stop light hooked in also. The stop light was so bright I had to put it on a lower setting or it would blind people. The dust light was so bright I had spots in my eyes.
I needed a dust light but didn’t care if I had one that would do disco strobing, multicolor crap. I just needed a dust light. Oh, I wasn’t going to spend $550 for features I didn’t need. I did some research and ended up buying one from Rigid ($220).
That thing put out so little light, I thought it was broken. I ran it for a few years and decided I was going to put it on my trailer and buy a proper light. I looked at everyone’s light and compared the output to my rigid. Now I see the problem.
Ridged output 715 Lumen
Everyone else (except KC) 715 Lumen
KC 4500 Lumen.
My fix, two high output yellow lights and use my light controller to strobe them. This is one of the reasons I need a solid state switched controller. I got the idea from one of the guys in my group. I think he just has a flasher module hooked to his.
The nice thing about this setup is, if it’s too bright, I can dim them for night time.
That’s it for now.
Day 5
Everything done except the power feed to the rear for the fridge.
Come to find out, my switch controller can be programed with my phone. I sat down, installed the labels and got the colors set. Everything tested including pulsing the rear dust lights. Shut off the truck, cleaned up and pulled it out of the garage.
Wait for it… And the light controller stopped working. Power/ground tested fine. Pulled back into the garage to do more testing and when I started the truck again, it was working.
key on/key off, looking for a pattern. Nothing. It work’s 1/5 times. Spent the rest of the day removing it and ordered a switch pro.
This is what I get for trying something new. Here’s an odd observation. When I researched it, there were no bad reviews. Zero. That should have red flagged this. There had to be someone out there who wasn’t happy. People leave bad reviews because it was raining when Amazon delivered something. I searched again, today and I didn’t see anything. Huh.
So…switch pro should be here tomorrow and Summer Santa just dropped off my HID upgrade for my headlights. As much as I like Toyota, their headlights suck.
I think I’m going to take tomorrow off and stare at the walls. get back to building later.
Haha.
Where you doing this?
Haha… *suspense
I’m really surprised you fit the ARB on the driver side! Awesome. I was so excited to see what you did with your build. Wish I was there.
Darn it! I didn’t even know ARB made a lighting controller.
Excited to see this in person!
I am very interested in the high output USB plugs. Can you simply replace the stock plugs with these or a stand alone wiring? Also, where did you get the plugs?
There’s a guy in Azusa I use. Turns out, I have been following this guys career since the 80’s. One man show and small shop.
I looked at them and another one from a major light place. Forgot the name. The other one was the same price as Switch Pro. I was hoping to find a cheaper alternative for people. There’s a common system I see people use that uses fuses and relays. It works but you don’t get the ability to strobe anything and its almost as much as the ARB. With my sample of “One” controller, I can say I have 100% failure rate with the ARB. All kidding aside, Installing these is too much work for a failure like I had.
I use Powerwerx for the round type. They make the better “round” type for lighter sockets and the highest output USB-C. They almost fit in the lighter hole. For rectangle switch blanks I use BlueSea 4.8 amp. You need to trim the hole some for them to fit. Powerwerx doesn’t make rectangle or I would use those for both.
Some phones and tablets wont charge unless the outlet and cord are rated as “QC4 or QC5” (QC3 is USB-A). Both of those brands will do that as long as their the high output with USB C flowing more wattage than USB-A. I think the powerwerx “USB-C” is the only QC5-100watt.
I also tend to run another feed to them. I want them powered all the time and most Japanese vehicles have the lighter on IGN only.
Day 6 (technically day 7)
Tearing out everything to replace that light controller took most of the day. Got the Switch Pros controller in. That means new mounting and building a couple of cable’s. That done, I moved the winch wiring to the auxiliary battery replaced the hook with a flat link. Of course, the positive cable is too short by four inches and gawd are those cables anorexic. I’ve never run one of the lesser brands but I’ve seen them abused while doing adapt a trail work. The lesser winch brands seemed to slightly underperform compared to the major brands and if they saved money by using smaller cable, that would be part of it. The lesser ones still worked but side by by side comparison to Warn and a couple of the bigger names, you could see the difference. Mind you, we abused these things badly. It wasn’t uncommon to see someone burn up a motor and cables had a short life span. The guys who ran synthetic cable needed to replace it about once a year. this was mostly from abrasion or large rocks crushing the cable. I’m going to do some testing before I replace the cables and I also don’t like the grade of winch rope. I wont replace it yet but will give it a thorough inspection later.
Ran a 4ga cable into the driver rear fender area with an 8ga from there back out tied back under the tail lights. Toyota installed a 12v accessory port and an inverter plug over the rear fender well. The 4ga is going to be tied to a mini sub panel to power whatever I need. The 8ga coming back out is for the charge wire in my trailer plug. I ordered a couple of breakers and two power studs and will tie everything in back there when they arrive. The one part I did finish was replacing the low power accessory plug with a high current one from blue sea, That will be for the fridge.
Next up will be installing the HID headlight upgrade and hopefully tomorrow the ditch lights will be here. Last night I realized I didn’t get a bathroom/shower tent for the side. I also was looking at awnings. I prefer 23Zero for these and as usual, everything is out of stock. Ordered the shower on back order and am deciding what awning I want.
Left on the list
  1. headlights
  2. Ditch lights
  3. finish wiring rear power
  4. waiting on bathroom
  5. waiting on bumper
  6. figure out rear storage
  7. Regearing appointment in two weeks
  8. Body mount chop. This will be done after I move. Right now I don’t have access to my welding and cutting tools.
Getting there.
A little side note here; When ordering parts, make sure you order for the vehicle your building, not your other vehicle. I couldn’t figure out why my cool new hidden Redarc plug and play trailer controller had the wrong plug. An hour later of research including a letter to redarc asking why the harness didn’t fit, I realized I ordered for my Tacoma, not my 4Runner.
On the bright side, I got my star link all updated.
Yesterday, I hooked up the wiring to the rear, installed the fridge and installed my HID headlights. In the passenger rear, above the fender, under the little tray, I made a mount plate for my breakers and my power post. When its done, I just pop the tray back in place to hide it. I love my 3D printer. We had a heat/humidity spike so I wasn’t out there too long. I also ran out of parts to install.
My ditch lights came in last night. I will be installing those today and doing the final mounting of my wire looms.
Forgot to update this. My trailer controller.
Recap; I picked up a Redarc Liberty Tow-Pro. It came as a kit with all the parts to be Plug and Play. The adapter harness to my 4Runner was wrong. Long story short I ordered a kit for my Tacoma and not my 4Runner. Before I figured that out, I had already sent Redarc a help ticket with part numbers and such.
Their response was…“Quick”? The reply started off with the reps name, title and (no shit) resume. He went on to tell me Redarc doesn’t sell “Kits”. All the pieces need to be ordered separately and all I need to do is “just order all the pieces”. He also typed an entire page detailing this and in not so many words told me I was stupid. What he never addressed was the fact, “I” ordered the wrong kit, nor did he answer my two questions.
Here’s the kicker. I got all the part numbers, including the part number of the “kit” they sell from their web site. I already have an attitude regarding their products. This just sort of tops it all off. If this guy is typical now I get it.
Bottom line. Already ordered the proper harness and lesson learned.
If I get the harness today, that will be installed also.
No new pictures
Got everything buttoned up and the ditch lights installed. it took an hour to properly mount the wire loom running along the rack. I don’t do zip ties for that stuff. Wont have the trailer harness until next week. I went inside when it hit 107 degrees and high humidity.
In a nut shell, six days, running 6-8 hours each. Rounding that’s about 42 hours.
Lets not add up how much that would cost in labor.
What’s left. Trailer harness will be here next week. Gear install appointment in two weeks. Rear bumper lead time is still 8 weeks.
Soon as I cool off, Ill get some pictures.
Here it is so far. probably wont look any different later until I get the rear bumper.
My Bartact Seat covers came in. This will be the third set I’ve owned and all I will ever do. The question here is, “how many different types of seat covers have I owned?” A bunch. Over the years I have not only installed them on my vehicles but, have installed covers for friends and customers. Their made from 1000D Cordoba. So slightly stiff but wear and stain resistant and tear proof. I really wanted them because I hate leather, especially black leather. Nothing worse than hot sweaty seats.
Install wise, not for the faint at heart. You really want to be familiar with upholstery. These are one step away from literally recovering the seats. Sometimes I think it would have been easier if they were. My only negative was trying to figure out how exactly to install them. Its a good thing they put detailed instructions in the box. Too bad I didn’t get any and there’s nothing on their site. Now that I’ve done a gen 5 4Runner, my next one would be simpler. I need to sit in them for a bit then resnug everything. Overall I’m happy.
4:56 gears are next week.
Pictures
Haha.
I take it this was for the trailer? … ah, nevermind, partly yup..
:person_facepalming:
Glad you got the Starlink dialed! So nice. I was in a situation recently in CO where my Starlink had too much tree coverage, barely had cell signal. Cell booster worked nicely in that situation.
Geez! 107.
I’m still in denial about that with my build…
Excited to see these in person! Thanks for the photos.
Not sure if I’ll do this later this year or next, we’ll see.
Appreciate you sharing the journey! Lots of good stuff here and parts.
Just picked up the truck from having the gearing redone. Went with 4:56 ratio. Was debating 4.88 because I may go to a 35 but, reminded myself that this is more overland than rock crawl.
I bought the truck with 33’s already installed and right off the bat saw the power problem. Normally, the vehicles would have come with a 4.10 ratio and I was surprised to find out it had 3.73’s. My Tacoma has 3.90’s and that’s bad enough but 3.73? UGH.
Installing taller tires and adding extra weight, works the driveline harder and can keep the engine outside of its power band. What your looking at is higher transmission temps and an engine that has to work harder. My 4Runner has a 5 speed auto and I barely let it shift higher than 4th gear unless I was going over 70 mph. The regearing brought my RPM range almost back to stock. If I had done the 4.88, the RPM’s would have been a bit higher than stock. This is still good except the lower the ratio, the smaller the pinion gear. What I didn’t want was gear noise on the freeway. I’ve run 4.88 with 33’s and its fine. One of my Jeeps ran 5.13’s and I had 33’s as street tires. I could do 70 without the RPM being too high but the gear noise drove me nuts.
I need to properly break in the gears. That means low speed for about 100 miles, letting it cool off in between, then easy driving for another 400 miles. I put about 50 miles on it before I tested my rpm at 60 and 70 quickly. Before, my rpm at 70 was slightly over 2k in 5th gear. Now its at 2k at 60 and 2400 at 70. This is right about where stock tire would be. I also noticed my acceleration is smoother.
Heading off to my new home in Utah tomorrow. The 4Runner isn’t ready for a long trip yet. It stays home. Be back next week to finish the break in.
No pictures
That’s all for now.
I have been running 33’s on my Taco since new. When I was researching gear ratios I found 4.56’s would be about 300 rpm’s higher than stock configuration. That is what I went with.
Well, I’m done for now. Still waiting on the bumper and haven’t drawn up the drawer system. I installed my awning, cargo box and bathroom enclosure. Of course it was over 100 degrees again. I cant wait for the move to Utah. Just got back and it was a high of 79.
Anyway, if i didn’t mention my preference for awnings, its 23 zero. Between my camping group and other people I’ve met, once you start actually comparing awnings, 23Zero comes out on top. In short, better structure, thicker multi layer material. Zippers are the same most companies use and I like their window’s.
Now the bad.
REALLY 23Zero? You discontinued your latest awning that I bought last year and this is after I had to wait SIX MONTHS for the wall kit because it was backordered???
Ok Rant off.
I don’t know what’s going on over there. They have a new awning out that absolutely rocks. Of course the wall kit is backordered so, screw that.
The awning I bought was OVS. They did some improvements last year and their local. If I open the 23Zero awning on my trailer and compare it to the OVS on the 4Runner, the difference is vey noticeable. Fortunately, the 4Runner awning is going to be used more for shade than shelter. I did give myself the option of walls, just in case.
The bathroom/shower I did get from 23Zero. Again, small features that make me go that way over the others.
The cargo box I got from OVS. All I can say there is “it was on sale”. As big as it looks, all I can fit is my recovery gear and the awning walls. I’ll keep one strap out but most of what’s in there will probably come out once in a while.
I took a few pictures but the sun was stupid bright so their kind of crappy.
The picture of the inside of the wall enclosure looks kind of pink/orange. Inside its not so much. The 23Zero would not have light bleed through.
