4Runner help please
I took my 2018 Runner in for a tire rotation and oil change today. I specifically asked them to check the steering wheel for shaking after because last time I had it done there, I got the shakes at 40 mph and then had to bring it back to get an alignment and balance. My son picked it up for me and I didn’t get to ask if they’d driven it like they said they would but sure enough, when I drove it the steering wheel shook.
In the 8 years I’ve owned it and had my tires rotated I have never needed them balance after a rotation. Alignment? Sure. I’m a girl, I hit curbs all the time :woman_shrugging::face_with_hand_over_mouth:
So tell me good people, is this normal? I know 4Runners are known for the shaking but to have it go from fine at 80 to uncontrollable shaking at 40 just seems a little sus.
Thanks for any insight you can offer.
On a completely unrelated note :upside_down_face: does anyone know a reliable shop in the Sandy, Utah area that I could take it for a tire balance?
Hey @Nicole ! I just had my tires balanced for the shakes within the past 48 hours. I had about 25,000 miles on the tires and hadn’t balanced them in a while. Thankfully the shakes went away… but I’ve chased this down before. One of my tires I had to do a road force balance on since it was “defective” I was told. The Hunter machine was asking for a lot of weight.
I sometimes have had the shakes after an alignment, I assume it was the configuration of the tires – one of the configurations after a rotation caused the shakes. Sometimes weights fall off which could knock them off balance. It’s possible one of the configuration of tires is causing shakes but when it’s rotated in the other configuration it’s fine. How many miles on the tires? How often have you had them rebalanced? If you’ve done it once recently, I wonder if it’s worth seeing if they’ll try to rebalance again, tell them it’s still shaking.
Note: usually during a rebalance, I believe they should see if a tire needs more than that and suggest a road force. Road force mimics the force of the road on the tires while balancing, it’s a bit more nuanced.
4Runners are notorious for this issue, though.
@Cassiano may have a suggestion on a shop for that can rotate. I’m tempted to suggest an offroad shop, but that may be a bit more specialized than you want for this.
Which shop or place did you take your vehicle to get a tire rotation, balanced at? And where did you go to do the alignment?
You could take your vehicle to Trav’s Automotive in Midvale to address the steering vibrations. They do alignments there. I’m sure they also do tire rotation and balancing as well.
If you think it’s not a balancing issue you could also take it to Horn’s Toyota in South Salt Lake for further diagnostic.
Another shop for alignment is Alignment Specialist in West Valley City.
Thanks for offering some perspective! It’s so frustrating that I asked them to check that it doesn’t shake. I am supposed to go down to Cedar City tomorrow and now I have to find a shop that can do it before I leave.
My tires are at 30% and 80% (front and rear). So they actually ended up not even switching the front to rear during the rotation because of that. It’s been about a year since my last rotation/balance. I don’t recall how many miles the tires have. I was hoping they would get me through an upcoming overland trip :wink: before I replaced them. I’m also open to ya’ll telling me to replace them before if I absolutely have to. :grimacing:
I went to Denny’s Automotive in Draper, that used to be Star Bros and known for their work on SUVs. Several of the employees even have Runners of their own. I think I’ve heard of Trav’s, so I’ll give them a call. Thank you for the suggestions!
For a tire balance, I think any good tire shop could help. If you are having some trouble with steering components, then a respectable shop would be better (I would probably start with the tire balance, though). There are plenty in Sandy. I usually rotate mine at home, so have not used a tire shop yet, but when I lost a tire for a no reparable damage, I use the Tire Discount close by. They seem to have done a decent job. I am curious about Burt Brothers Tire & Service. I may use them the next time I need a specialized tire service.
30% tread is getting low. You could choose to replace them with the exact tire or wait til the 80% wears down as much as you can before the winter comes around. But eventually you will have to replace 2 tires or all 4.
Damn. Sorry you have to go through that, What your describing is a lack of training on the tech and or bad shop policy. sadly, your issue is very common.
Here’s how it is suppose to be.
  1. Tire rotate “every” oil change.
  2. Balance “every other”
Here’s why.
The rotate part is generic. As you turn(steer), the edge of the tire gets chewed (scrubbing). The right front is the worst. Rotate puts the chewed tire on the rear and that flattens the tread back out. That’s the basic’s. In reality, If you drive more freeway, less scrubbing. If you drive more windy roads, more scrubbing. Tread design and how soft the tire is, also play into this. Mud tires are worse than AT’s. My competition NItto Mud grapplers would chew badly if I drove 200 miles on the street. My Cooper AT’s almost didn’t scrub at all.
That’s why we rotate.
Balancing is necessary because the tire scrub isn’t going to be even as well as running over things or what ever causes tires to be uneven. Another thing here is, tires are not perfectly round. What you get is a slight bounce. This can be up and down or more diagonal. The second one is tire shake. A tiny bit of bounce causes the tire to be more “out of round”. This issue wont stop at a point but will get to where the tire can no longer be balanced. You end up with egg shaped tires.
Unless someone asks, I wont get into the types of balancing but I can tell you this, not all balancing machines are the same. Lazy and (or) poorly trained tech’s will not properly balance tires even if they have the proper machine.
For our off road tires, rotate/balancing is more critical especially if you run softer tires and drive more mountain roads.
One more thing. Tire quality plays a big part in this. I mentioned my 35" Cooper AT’s. Worst tires ever. At 3k miles they wouldn’t balance. The machine told me they were not round at all. I first suspected a rim issue so I tested the rims. All perfect. The rims were new “Fuel” rims. Some rim’s are not made well and can be out of round. I never had that brand so I needed to test them. Five not round tires and one was so bad I had to put it as my spare. It shook that badly. I contacted Cooper and they said I obviously abused the tires. FYI, they hadn’t been off road yet. They got worse over time and I replaced them the next year.
Off road I run between 15 PSI and 25 PSI. I also tend to drive aggressively. Low pressure can deform the tire, that’s what Cooper was claiming. I literally made them worse by dirt road driving at 20-25 psi. The tire was not made for dirt, only street.
I know, a bit wordy. Comes from my profession. Believe me when I say, I just touched the basics on tires.
Probably a bit late on this thread, but I’ve always used Big O Tires off of 700 E in Sandy. Sure, they are a big brand store, but they have a knowledgeable staff and the guys there are great. Between my dad and I, we’ve bought 6 or 7 sets of tires from this shop, and we won’t go anywhere else. Can’t recommend them highly enough.
Thanks, everyone. I took Hoa’s advice and called Trav’s. I’ve been there before and recognized the name. They were able to get me in first thing Friday morning. All they had to do was switch 2 tires and it completely fixed the shaking steering wheel. They didnt even charge me and their tire price quotes were nearly $300 less than the previous place. They said I should be fine for my upcoming trip but probably need to be replaced before weather hits in the fall/winter. I’ll def be going back to Trav’s. Great service and care!
I’m on my second set of Wildpeaks and have really liked them but if anyone has any suggestions, I’m open to try something new (except Coopers, apparently :wink:)
Thanks again for all the input!
I like my Wildpeaks. I ran BFG’s forever and bought my the last set right at the end of Covid. Evidently, something happened to them during that time and their quality went to crap. This is what replaced my Coopers on my Cruiser. I put Wildpeaks on my Tacoma and have been happy for about five years. I just bought a 4Runner and that’s what I’m buying for it.
What I have found with tires is, they can evolve every five odd years. What one person ran on their truck may be better now or not today. I have seen quite a few of the cheaper, less known brands of off-road tires and none of them were any good.
Every time I had the shakes on my Tacoma, it usually starts at 40ish mph and stops around 55 mph, I had to have my tires road forced balance. First, the shop has to have the machine to do it. Not all shops can do this, so check first. Second, you have to request it. This type of balancing is more expensive, usually $50 a tire. When Denny’s was Starboys, they had the machine and an excellent mechanic that could do this. Wonder if he left. I am glad to see it was something more easier (and cheaper) in your case.
So grateful for all the discussion here. Glad you got the issue sorted (albeit in the short-term @Nicole ). I’ve dealt with this before and appreciate the nuanced learnings.
@Nicole , do you happen to know which two they switched? I have to imagine certain unbalanced tires are more prone to causing this.
I’d also be curious, what does that mean? One of the tires isn’t balanced properly? The wheel could have an issue? The tire could be defective? All possibilities? Note: I have one tire that is always giving me issues, I need to road force it. I still have a tiny bit of shake at 45-55mph (after a 4-wheel balance + road force on one of them). I like this video for explaining a road force balance, just pulled it up.
PS. @Smritte , added a new :fire: emoji reaction for long thoughtful posts! A :heart: couldn’t do that justice. I appreciate all the nuances of this stuff, particularly since I’m dealing with a “trouble wheel.”
They do still have the machine. They told me until I replace my tires, nothing I do will fix it. Which turned out to be untrue since Trav’s was able to stop the shaking.
I believe they switched a front to back, on opposite sides. It just frustrated me that it wasn’t shaking before I brought it in, so I knew it was possible to fix it without buying new tires yet. And I know that depending on where they are placed could make them unbalanced, but it was possible. There’s a lot of factors, one of which is because of the shaking the first time they rotated my tires, they wore extremely unevenly on a road trip to the PNW a year ago. Afterwhich was when I got them balanced.
I have had trust issues with this shop since they told me I needed parts and repairs that I’d just had done before switching shops. I had gone to Fat Bob’s for suspension work and within a year was being told I need new bushings. When I went back to Fat Bob’s to confirm this, they looked and said they were fine! Sooo frustrating they tried to take advantage of me, assuming I didn’t know better.
I do appreciate all the help and advice here! You guys rock!
Good video on road force. That was almost exactly how I did my tire lecture. I even have two of the black wheels for demonstration.
A common complaint from a tire rotate only is shaking or vehicle pulling. That comes from a n out of bal or bad tire. A common temporary fix is just put it on the back. I would be happier to know they said if the tire is beyond saving. Either way it won’t get any worse on the back.
Regarding your suspension bushings.
Ugh. This is hard for me to say. Quite a few shops, including off road specialty shops don’t actually install suspension correctly.
If done improperly it ruins the bushings pretty quickly. Faster if you go off road. The issue there is, they can be installing suspension for years and never know they’re doing it improperly.
The shop that said the bushings are bad needs to show you how they know this. If they’re correct the other shop is covering their ass and will not admit fault. Of there’s nothing wrong with them the shop that said their bad is ripping you off.
One more thing. If you drive like I do, bushings wear out fast. This is why I go to heim joints.
I would take it to Agility Customs and have Geoffrey Beers look at your suspension. He is one of the Toyota experts in the area, and he won’t BS you. I know the Denny’s in Riverton tried to tell someone I know that their cv axle was shot. It had a slight amount of movement. I told them to take it to CV Axle Express. This is all they do. They said the amount of play was normal, and did not charge them. Also some other issues with the Riverton Denny’s, but we won’t get into that.
Also, if you need cv axle boots replaced, take it to CV Axle Express. They will replace the boots, not the entire axle assembly. Save you well over $1,000. Again, this is all they do and have the equipment to do it.
I second Geoffrey Beers, have done a significant amount of work with him at Agility Customs should it ever make sense.
